I’m trying to evaluate the speed of my network, even if I do not have any problem streaming large file (12 gb MKV file). Some tests that I made concern me. Here is my setup:
WD TV Live Hub
Router: Cisco WRT400N
USB Wifi: Linksys WUSB600N
My PC: Windows 7
I’m using the 5ghz frequency
Because there is no tools on the WD live to evaluate the speed, the only test I can think of is to copy a large file on the local HD of my LIVE Hub or send ping command.
Copying file from my WIndows 7 to the local HD of the Live Hub gave me around 4.40 m/sec, so around 40 mbps / sec. This is not very good considering the capability of the 802.11 N standard on the 5ghz freqency.
The ping test gave me this result: (ping -l 10240)
Réponse de 192.168.1.13 : octets=10240 temps=9 ms TTL=64
Réponse de 192.168.1.13 : octets=10240 temps=4 ms TTL=64
Réponse de 192.168.1.13 : octets=10240 temps=6 ms TTL=64
Réponse de 192.168.1.13 : octets=10240 temps=8 ms TTL=64
Réponse de 192.168.1.13 : octets=10240 temps=13 ms TTL=64
I would like to know what speed are you getting on your network so I can compare to mine,or what test did you make to evaluate the speed of your network
Thanks for your time
Charles-Andre
