Mutliple external audio and subs how to?
Ok so I have a file: example.mkv
I also have 2 SRT files example-English.srt and example-french.srt.
First question how can I name these files so that they both show up in the subtites list?
Also I have example-english.mp3 and example-english-surround.ac3
Is there a way to name these files so WDTV picks them up as available audio trakcs?
My goal here is to not have to mux (combine / convert) any of the files together.
I would assume not as the subtitle tracks have to have the same title as the movie. However you could remux them into a new mkv using mkvmerge, it should only take seconds or a few minutes.
im 90% sure there is a way to do it with subtitles but i cant remember exactly how. But the audio I have no clue on.
I think you will find that you can do it all with mkvmerge. mkv is just a container and it can contain video, subtitles and audio tracks. I have not done it myself but its very easy to give it a go.
http://www.bunkus.org/videotools/mkvtoolnix/downloads.html
yes thank you. Ive done that before but Id was curriouse if there was a way to do it with out muxing it, thats all
External audio does not work, nor external PGS. External srt works as long as the stem is identical. Usually one would name them like this:
example.mkv
example.en.srt
example.fr.srt
ok thank you.
