Hi, this is my first post so please go easy.
I am having problems playing files from my Kodak Zi8 on the WDTV Live. The file plays ok, but the audio falls out of sync. This is the media file…
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 1.22 GiB
Duration : 24mn 49s
Overall bit rate : 7 020 Kbps
Movie name/More : KODAK Zi8 Pocket Video Camera
Encoded date : UTC 2010-03-05 13:26:16
Tagged date : UTC 2010-03-05 13:29:09
Writing library : Apple QuickTime 7.6.5
com.apple.quicktime.player.movie : (Binary)
Origin : Digital Camera
AMBA :
Video
Format : AVC
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 24mn 49s
Bit rate mode : Variable
Bit rate : 6 887 Kbps
Maximum bit rate : 12.8 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 36.690 fps
Original frame rate : 29.970 fps
Minimum frame rate : 19.982 fps
Maximum frame rate : 59.960 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.204
Stream size : 1.19 GiB (98%)
Language : English
Encoded date : UTC 2009-12-25 13:31:15
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 24mn 32s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 22.5 MiB (2%)
Language : English
Hope someone can help
