Theme Modding
I really like this theme [Extreme_FinalMix_DVDCase_3_SHEET] for movies:
Here is an example:
For TV I have modified Extreme_FinalMix_SHEET to work more with TV episodes.
Example:
Two things I havent been able to figure out so far to complete the modifications for my liking.
  1. in the TV one I would like a header above the cover image that says “TV” or “TV Series” like the DVD one has.
  2. I would like the blank blue area at the bottom transparent on both [especially TV] so I can see the files in the same folder. Or maybe make a trickle in there.
Any help in pointing me in the right direction would be appreciated.
drizzt09, Nice work on the TV Sheet…
Send me your template via pm and i will modify it to include the TV cover box
As for transparency use firetix method :-
Remove the background and create as a .png using thumbgen then remame the file manually to .jpg
PM’d you.
Ill try the transparency once I get it back from you.
You know how to make Trickle affect for it?
Here you go
http://www.mediafire.com/?4icyk796e1likh5
I will be looking at making a new mega template pack 1.8 which will include these, but just download as add for now
There is an extra coverbox png just put that in
ThumbGen\Templates\Template_Mega_Pack_1.7\Common\Boxes
Enjoy
