Friends of the Community already asked about this issue here in the forum, but could not get a solution yet.
The theme is Darklight (Beta v2) and the firmware is the latest version.
Have deleted the library by setting the Hub, since manually deleted the files created by the hub in hd, but the problem continues.
See how is my moviesheets. No 1 in the picture it appears certain, normally, but the picture No. 2 they appear square, as if only the image it without rounded coverage. In truth the image is the same as the No. 1 because it occurs? already returned the firmware to 2.8.13, and the previous version of the current, but not solved. This is not all files, some appear normal, but some insist on appearing as well.
I’m having the same problem, and I can not solve.
It’s a Firmware Related Issue which started with Firmware 2.08.13 (And has not been Resolved by WD)
Tinwarbles Issue Report Here:
If you Rollback to Firmware 2.07.17 you will not have any problems.
