still working on gallery wiev but thinking of how other wievs should look and then i came to think can poster images be showed at an angle? fx in list wiev where you have the list and then you have a big poster can this be in an angle
and the bonus ? can things be excluded from the home menu like i really dont need the sling player
Tinwarble said NO
when the answer is yes, with a twist. Need to customize the theme to exclude it, but it can be done. He did ask if he could remove the feature, or turn the fetaure off. He asked if it could be “excluded from the home menu”.
Actually the “And no” was to the respose to the second thumbnail angle question, since it was asked twice. Once about the poster in the Gallery view and once about in list view.
I didn’t really answer the question about removing main menu items. My bad for not clarifiying.
Of course you can remove any item from the main menu by editing the “inc_rv_home_menu_node.xml”.
