Reply
Regular Advisor
hazmat96
0
NETFLIX movies drop audio (and sometimes video) briefly
Running FW 2.07.17, although I was at 3.03.13 briefly and had the same netflix problem.  Placed this in "networking issues" since that is my guess on why.  Anyone else seeing this dropout every few mins?  I am hardwired to a gigabit LAN on CAT6 and am sure this is not a wiring issue since I use a line tester when I make up a network cable.
Thanks,
Mike
Honored Contributor
Alucardx23
0
Re: NETFLIX movies drop audio (and sometimes video) briefly
[ Edited ]
Hi, try pressing the reset button for 1 second.
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Occasional Visitor
The_Vato
0
Try changing your audio output to stereo. I have the same problem sometimes when I am just playing a movie on the drive and that works. With Netflix sometimes the audio still won't play and I have to go to the xbox.
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
