Reply
Occasional Advisor
dingo
0
Accepted Solution
Where is Flingo in 3.05.10
[ Edited ]
Updated to 3.05.10 and now cannot find Flingo section which has TED talks. Anyone have the same problem? or ideas.  How do I get it back?
Honored Contributor
Alucardx23
0
Re: Where is Flingo in 3.05.10
Try pressing the reset button on the bottom side for 1 second, if that doesn't work try rolling back to the previous version and then reinstalling the latest version again.
http://wdc.custhelp.com/app/answers/detail/a_id/5860/session/L3RpbWUvMTM0MDkwMTgzMi9zaWQvMjk4UGFQX2s...
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Occasional Advisor
dingo
0
Thanks for the prompt reply Alucardx.
I should say I have two of these devices both with the same update and both have the same problem. So this is not isolated to just one device.
I tried resetting without any luck.
I downloaded 3.04.17 extracted to a USB and when the menu comes up hit cancel as instructed but there is no Firmware menu as indicated in the instructions. I tried several USBs and eventually a new one but no luck there is no firmware menu.
The same problem exists on the second device and I am believing it must be a firmware issue. If this were the case then someone else must have come across this (I would have thought) I can't be the first I'm never first.
Anyhow still looking for suggestions but think this is a WD firmware issue and hope they are online to advise.
Cheers Dingo
Respected Contributor
foetus
SERVICES\WEB VIDEO\LAUNCHPAD
Occasional Advisor
dingo
0
Foetus.... Thank you
Man o man I feel stupid now.
I looked at everything just didnt see where Launchpad said powered by Flingo.
All good now many thanks
Dingo
foetus
0
no problem
I like watching TED presentations
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
