i just bought a new router for reasons i cannot really discuss i separated my lan in difrent segments and ip networks
suffice to say being separated is easyer than machine by machine for managing my firewall. i just need to put the port in the right “vlan” or segment instead of just doing an intire setup port by port.
now my WDTV is in 10.30.30.0/24 is it possible to “statically” add media servers (dlna) in the WDTV ?
i can add them because of the dlna servers will be fixed IP addresses ( dynamically assigned tho but always the same)
when i change the subnet mask it dosent seam to look for the servers in other ranges :-( so it only looks for 10.30.30.255 or somthing . dlna servers would be in 10.10.10.0/24 and 10.40.40.0/24 ( 10.40.40.254 for example) so WDTV would have to look for them in a diffrent subnet.
