Reply
Honored Contributor
DeVicious
0
Re: Special Release - Firmware Version 3.03.16 for WD TV Live Hub (4/4/12)
Yeah I see what you mean, i thought I mentioned before that the bottom table would need to be unified as a compromise.
Then you could do the bottom part just fine but the poster area obviously not if you want a reflection there as well.
If you don't provide a solution to solve a problem - you are the problem!
Occasional Advisor
Baignoire
0
depuis la dernière mise a jour cela me fait des duplicata a chaque fois que j'efface un fichier.
since the last update it gives me duplicates every time I delete a file. :smileyfrustrated:
Occasional Advisor
Baignoire
0
can we get help following is a recurring problem of duplication when deleting a file thank you in advance
Occasional Advisor
dmacleo
0
ton of skipping when playing iso from remote share, rolling back now. was never a problem before this version for me.
Honored Contributor
DeVicious
0
does it physically duplicate the file or does it just show on your live hub?
I am deleteing files/folder on a daily basis and this has never happend to me. However I have the library function turned off. Could you test it please by deleting a file when turning the library off and see what it does, that would narrow down the problem.
Occasional Advisor
Baignoire
0
it shows me all the duplicate file, but actually there is only one file that makes me hersince this update and yes I board the library enabled
Occasional Advisor
Baignoire
0
[ Edited ]
so yes if I disable the library the problem disappears thank you solve this problem in the next firmware
Visitor
Nikoleta
0
Hello to all,
I am  new here and desperatelly nead some help. I have WD TV LIVE Hub and I have problem with this new Firmware Version 3.03.16. All my MKW movies with Dolby Digital sound now dosen`t  have sound. The video works fine but there is no sound. The other movies with DTS works fine and there is nice 5.1 sound but this one with Dolby Digital there is no sound at all. There is no problems with the old firmware and now I deeply regret that I update my firmware and a lot of movies dosent work because there is no sound.
If someone can give me ideia what to do or how to downgrade the firmware with the old one I will be very greatfull.
Sorry for my terrible English and regards to all.
Nikoleta
Trusted Contributor
flhthemi
0
Nikoleta wrote:
Hello to all,
Nikoleta
Downgrading the firmware is refered to as "rolling it back". I would suggest rolling back to 2.07.17. Here are the files you'll need and the instructions.
http://wdc.custhelp.com/app/answers/detail/a_id/5860/
Hub Manual:http://www.wdc.com/wdproducts/library/UM/ENG/4779-705046.pdf
WD TV Live Hub - WD TV Live Plus
Asus Transformer Infinity TF700 - PS3
PlayOn Media Server
Visitor
Nikoleta
0
Thank you so so much. I downgrade to the Firmware Ver.  3.00.28 and now everything again works fine. I cant understand why WD issued new firmware which maybe fix something but ruin another. There is  no sence ........
Anyway thank you very much.
Regards :smileyhappy:
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
