Reply
Regular Advisor
tm9ZL34UhIf68B2
0
Random Drop outs to Navigation-Menu while selecting Chars with the Remote
[ Edited ]
I wonder if someone else noticed this, but i have random Dropouts to the Navigation-Menu while selecting Chars with the Remote.
This is very annoying and happens while entering longer Strings with ethe Remote, doesn't matter where i am it simply drops out to the Navigation-Menu and i have to start over again...
1 x WD TV LIVE(Dead!), 1 x WD TV LIVE HUB (1TB), 4 x QNAP659Pro (18TB/RAID5 15TB), 2 x QNAP869Pro (32TB/RAID5 28TB), 58 x 2TB WD Elements | 100Mbit Fiberoptic Internet | Netgear Gigabit Router | Cat 6 SSFTP Cableing | Dreambox 8000 (2 x SAT, 2 x Cable, 2 TB)
Occasional Visitor
nschlueter
0
Re: Random Drop outs to Navigation-Menu while selecting Chars with the Remote
I have seen this as well. For me it happens when I am trying to refine the video's file name so that the on-line movie database can find information. I haven't been able to identify a repeatable sequence of events but it happens often enough to be annoying.
Regular Advisor
tm9ZL34UhIf68B2
0
Yeahh, i think the first Time i noticed it was like you while refining eg. deleting at the end of the Filenames to get the Metadata... But it seems not to be limited there, its happening everywhere, especialy on longer Operations with the Remote, like entering Accountinfos for Pandora or entering the Username/Password and also Youtube Searching... Its sometimes hard to enter all the needed Info  without being dropped, so i try to be fast enough and not to loose to much Time, but its very random and not really predicable.
First i supposed something like wrong Codes sended from the Remote, two Codes that are not so clearly separated or something like that, but can be everything. Perhaps i should test it with an external Keyboard also to check if it is a Remoteproblem or happens with the Keyboard too, but i first must go buying one tomorow for that.
Honored Contributor
TonyPh12345
0
I have seen things like it, too, but I have NOT seen it since I started using my Harmony.
What I think is happening is accidentally hitting the BACK button, which is awkardly placed on the remote...
But, of course, if it's dropping out to a place DIFFERENT then where the BACK button would go, of course that wouldn't be the case.
But since the Harmony uses the same codes (learned from the Live+) I don't think it'd be a IR Coding issue...
===Live SMP / Live Hub x2 / Live+ / Live x2 / 24 TBytes of QNAP + WD NAS ===
Regular Advisor
tm9ZL34UhIf68B2
0
Yeah, it drops out to a place DIFFERENT then where the BACK button would go!
If i'm editing the Username/Password for the internal HDD-Access the Back Button don't bring me to the Mainscreen but to the Settingsmenu i think, so its more like pressing Home accidently, what is not really possible while only pressing the Arrows... *lol*
I taked reallly care to not press the Back Button, it happens while pressing only Arrows, so its something strange, or the Code of one of or all Arrows are allmost the same as Home and is not allways detected correctly? Well dunno, but its annoying...
Honored Contributor
TonyPh12345
0
Well, HOME would take you to the MAIN MENU, not any Sub-menus.   Going back to the SETTINGS menu DOES sound like the BACK button.
Regular Advisor
tm9ZL34UhIf68B2
0
Did i say it brings me to the Sub-Menu anywhere? No! I said to the Navigation or Mainmenu that is the Mainscreen, the one that comes when pressing HOME and also comes ater Booting it up. Hopefully its clear know where the Drop leads.... Well, probably better i look for another Device because it starts boring me to wait that all the various annoying Bugs get fixed anyway, well WD seems ok for HDD's but not really for Videodevices!
Honored Contributor
TonyPh12345
0
[ Edited ]
Uhm,  YES!  >>>  the Back Button don't bring me to the Mainscreen but  to the Settings menu i think
The Settings Menu is a SUBMENU.
Regular Advisor
tm9ZL34UhIf68B2
0
Uhm, No!
If i'm editing the Username/Password for the internal HDD-Access --> (Which is located in a Sub Sub Menu of Settings) ---> the Back Button don't bring me to the Mainscreen but to the Settingsmenu i think, so its (The Random Drop is) more like pressing Home accidently.
So what i mean is, the Random Drop IS NOT like pressing BACK, its more like HOME, because if it is like BACK then i would landing in the last Submenu or Settingsmenu not on the Mainscreen/Navigation/Mainmenu and completly out of anything, also  like it happens with pressing HOME.
Anyway i'm not pressing back accidently, it happens while pressing only Arrows, it happened so many Times, that i really watched exactly do not press Back accidently, but it dropped my, so pressing accidently Back is really out of the question here!
Valued Contributor
architectonic
0
[ Edited ]
HEY tm9zL34uh.........!!!!!
YOU'VE GOT A SERIOUS BAD ATTITUDE MAN!
WISE UP.. PEOPLE ARE ONLY TRYING TO HELP YOU!!!
AN APOLOGY TO TONYPH12345 WOULD BE A START.
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
