12-25-2011 10:41 PM - edited 12-25-2011 10:43 PM
Milkieboy,
Mine is plugged in just component. Your switch box has nothing to do with it. My setup hasn't changed since updating the firmware. This is clearly a bug with the new firmware.
Please upvote this issue
12-27-2011 04:47 AM
Rolled back to 2.08, TS's play, but Mkv's and ISO's won't play. The ISO's reset the hub.
cwh
12-27-2011 06:58 AM
chris060 wrote:Rolled back to 2.08, TS's play, but Mkv's and ISO's won't play. The ISO's reset the hub.
cwh
Reset the hub by pressing the bottom paperclip button for a couple of seconds and then release with the hub fully booted up.
12-27-2011 09:08 AM
Thanks richUK, I should have been more clear in my statement.
Playing the ISO's using software version 3.0.1 causes the Hub to reset/restart itself without human intervention.
Going back to 2.08 software, the ISO's play just fine.
cwh
12-27-2011 03:23 PM
chris060 wrote:Thanks richUK, I should have been more clear in my statement.
cwh
I understand. I was suggesting that you use the reset button on the hub with the newer firmware to determine if that cures your problems. However if you are happy with the rollback then I would stay there.
12-27-2011 05:06 PM
wdtvhub wrote:
And what QC process did this go through, the Russian music app speaks volumes !!
The russian app was only supposed to be available in Russia.
12-27-2011 05:13 PM
drizzt09 wrote:yes you are correct all folders in Windows[not just 7] are default to READ ONLY. However when you SHARE them wihin Windows you need to set permissions[write access]for the user you are sharing with[the user profile you log in using the hub].
Not if you use an anon account, and there is no way in heck I'd give it write access.
12-27-2011 05:21 PM
12-27-2011 07:23 PM - edited 12-27-2011 07:25 PM
I see absolutely NO POINT in WD insisting to add "new features" if NEW (and old) BUGS just continue to appear like no tomorrow!
STOP adding useless "features" !
FIX ALL THE BUGS ONCE AND FOR ALL !
Everyone wants that, not only me. Is so much to ask?
12-27-2011 07:27 PM
Besides, the link:
http://download.wdc.com/wdtv/Rollback_wdtvlivehub_
Is still unfixed !
| Forums | Ideas | News and Announcements | Register | Sign in | Help | Forum Guidelines | |
