Reply
Advisor
ix400
Re: New Release - Firmware Version 2.07.17 for WD TV Live Hub (8/2/11)
I would predict that 95% of all Live Hub users do not use the Facebook App.
Chris
Advisor
YasrKasem
0
you can add me to the list
but what about the software stability, bugs bugs reported so far?
WDTV Mini, WDTV Live, WDTV Live Hub, 1TB Mybook Essential.
Valued Contributor
ramx2
0
Personally, I'd rather prefer Twitter instead of Facebook!
Frequent Advisor
lemonkid
0
Who is talking here about facebook? Does the hub have a facebook app??????!!!!???  Hrmpf.....!
Visitor
broadsword
0
[ Edited ]
just flicking through this thread i really just cant believe that some many people are having some many different issues with this product... did i go to sleep and are WD owned my MS and we are all paying to test their products or is that just the way of the world now... either way its [deleted]... its not rocket [deleted] science is it... what a world hey!
Occasional Advisor
tkay564
0
dhadleymail wrote:
I've had issues with the last firmware that some of my 720p mp4 movies would stutter every 10 seconds or so. Does anyone know if this release resolves any of those issues?
I would also like to know if 2.07 makes any difference to that. 2.04 is currently the latest that plays all mediatypes i have flawlessly.
Occasional Collector
eclipse1978
0
I have been experiencing the same issue as well. I keep loading the latest firmware hoping the issue has been fixed. Will test after the load finishes, then report back my findings.
Occasional Visitor
Alejkeyb
0
Hey Man thanks, totally works for me, just conect direct wire from your Routher, hub, switch or whatever you have, and put an static ip nad reboot. Like a charm. Thank you again DrMac :smileywink:
Trusted Contributor
NYTEMAYR
0
No installation problems using auto update!! Facebook stuff is fun!! new games!
Trusted Contributor
flhthemi
0
Did my update via the update check. It took about 20 minutes and works fine. Well, with the execption of Shoutcast not finding anything at all. Tells me "This shoutcast station is not available, try again later" Might be shoutcast but I get it a LOT. But I don't use this thing for music anyway...so i guess I'm just sayin'.
Hub Manual:http://www.wdc.com/wdproducts/library/UM/ENG/4779-705046.pdf
WD TV Live Hub - WD TV Live Plus
Asus Transformer Infinity TF700 - PS3
PlayOn Media Server
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
