Is there a way to network two TV Live devices to a TV Live Hub wirelessly, without using a router/hub?
Also, what is the max number of TV Live devices that any of you has used to stream video simultaneously from a TV Live Hub? Is there a limiting factor?
Thanks!
No, and for me, three.
The limiting factor is the network, of course, and the bandwidth demanded of the Hub. If you stay below, say, 50-60 megabits per second total, it will probably work fine.
