I broke my remote (because my brain is small). Is there a way to manually update the firmware? I downloaded the latest version and extracted the files to the root directory through File Explorer on a PC in the house (I believe). I then turned off and on the WDTVLIVEHUB. No dice on the upgrade as the opening screen shows “New Firmware”.
Thanks for that insight. I would LOVE to login to the Web UI. No idea what the password it. I believe I did change it way back when. Someone posted that you can open the database.db file in notepad to see the passord. I did so and didn’t see anything.
Any ideas to reset the password with no remote?
Yes, do a system reset by pressing the RESET button (on the bottom of the box) for 1-3 seconds with the system already booted.
