So, i want to update it to the latest firmware ( 3.01.19) Should i just straight update it to that?
I read so many horror stories of the new firmware screwing up their Hubs…
PS: i never use the streaming/online/WIFI services
Yes. I updated fine using the online mode. It does it all in stages. Just keep on updating from that menu as different versions show up.
but i don’t have an WIFI adapter, i don’t use the online options. I just upload content to the media through a good old ethernet cable. Should i update with an USB dongle directly to 3.01.19?
Easiest way is to have the hub connected to internet and update it that way. If it’s offline just go to: http://www.wdc.com/wdproducts/updates/?family=wdfwdtv_livehub
scroll down to “How to Install the Product Update:” and follow the instructions.
Good luck!
