I know that DVD structures are recognized by the player,would it be possible for the unit to recognize Blu-Ray structure. Thanks in advance Mark
Hello, if you refer to Blu-Ray rips, yes they are compatible.
if i rip a blu-ray to BDMV and CERTIFICATE on to the streamer it will play like similar DVD structures do. Regards
it’s not possible currently
same is true for any linux based system, no blu-ray menu’s
but the individual files do play just fine
are you talking about the .ts files
.m2ts files.
The player find the largest one and plays it. No menus nor will there ever be any.
