Hi…I love my WD LIve Hub but am finding it very frustrating to operate. All I want to do is click and drag movies from my desktop computer to the WD Live Hub but cannot seem to do so. I dont want to use twonky or anything else like that…is there a way to do this?
Just a general set up question. Have you set up your media hub with a lan cord to your router/moden which is hard coded [I assume maybe wireless] to your computer / laptop?
Better than drag and drop, why you just don’t make folder sync with your PC/Laptop
very simple way to transfer you newly arrived movies to the HUB.
From your HUB setting choose sync from network and choose the movies folder (or any other) on your computer this it will sync automatically once the folder have new content.
