Hi everyone is there a way of seeing the up time on the wdtvlive hub so I can monitor how often the hub is rebooting.
I think there is a way threw the network to do what your asking.
Thanks for replying Lawrence, can you shed any further light on how over the network I might do this? Telnet session to the WD or some sort of monitoring system maybe? Thanks
No, it’s not possible.
Tony, thanks for replying, i dont suppose you have any ideas on how i might get the information i want? Basically, ever since the new firmware upgrade the WD randomly reboots and I want to get an idea of how bad the reboots are when I dont happen to be using it. Thanks
Here’s a rather BRUTISH way of doing it. This was tested in WINDOWS 7.
Create a TEXT FILE named
testhub.bat
on your desktop.
Put this in the text file:
echo BEGIN > output.txt
:top
echo ************************************************* >> output.txt
ping -n 1 xxx.xxx.xxx.xxx >> output.txt
date /T >> output.txt
time /T >> output.txt
choice /d y /t 5 > nul
goto top
Replace the xxx.xxx.xxx.xxx with the IP address of your Hub.
Save the file.
When you double-click the resulting icon, a window will pop up, and you’ll see the program executing.
Feel free to let it run as long as you wish.
When you want to examine the results, when that window is ACTIVE, press CTRL-C. You’ll be asked if you want to terminate the program. Answer by pressing Y.
You’ll find a new text file on your desktop named “output.txt”
Open it in notepad; it’ll look like this:
BEGIN
Pinging 10.0.0.10 with 32 bytes of data:
Reply from 10.0.0.10: bytes=32 time<1ms TTL=64
Ping statistics for 10.0.0.10:
Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Thu 04/28/2011
06:25 PM
Thu 04/28/2011
06:25 PM
You’ll see the results of a test, executed every five seconds via a PING command.
Search for the ones indicating TIME OUT or HOST UNREACHABLE (not shown above, since my hub is up and running)
After each iteration, there will be a DATE and TIME indicated so you can see what time of day it rebooted.
