WDTV Live Hub Media Center won't connect to network
Similar to others I’m having trouble connecting the unit to the internet.
I have the WD Live Hub Media Center connected via Ethernet cable to my D-Link DIR 625 router that is wirelessly connected to my network and is function OK.
When I go through the automatic network connection step it seems to pick up the IP address, subnet mask, gateway and DNS numbers OK and displays them on the screen.  However when I test the connection it shows a green checkmark for the IP address and a red x for the DNS and Internet connection and says that the DNS number is not correct/valid.
Ant help or suggestions would be greatly appreciated!
Cheers!
Hello psampara, try manually setting the DNS on the WD to 8.8.4.4 or 8.8.8.8  (Google DNS)
