Dear all,
I already checked various older threads (i.e. http://community.wd.com/t5/WD-TV-Live-Hub-Discussions/Help-Hub-powers-up-WD-light-flashes-then-powers-itself-off/m-p/112920#M3845) but the problem looks different.
Mostly each time I unplug the power (even with the Hub switched off obviously) the Hub fails to start at next boot and shows only the start screen to become after a while blank with blinking led until I do not “Rebuild database” and /or - (I always try both operations to succeed) and “clear logs” from Twonky Media .
A couple of times I need also an hard reset.
Since I move the Hub from one TV to another frequently it became quite frustrating and time consuming, especially because in the 2nd tv I have to move the Dlink powerline together with the Hub in order to perform said operations, not counting that I have to switch on the PC in another room, go back and forth several times, while I would simply enjoy a movie stored in the HUB and no connection to network shall be needed.
Hardware is WDBACA0010BBK-EESN
Firmware is 3.12.13
Storage usage is 921.41GB / 930.44GB (40% music the rest movies, no pictures)
Media Library is OFF - if I activate it the chance that the HUB will boot properly even keeping it powered are very low
The quantity of data this is the only reason that keeps me to turn the HUB to technical assistance, since I am experiencing also (relatively) minor problems like impossibility to see the HUB in the Network by any PC, so move and/or play content from the 2 PC connected or using DLNA properly.
Any feasible solution that do not compromise the warranty and avoid me to buy a much more reliable and handy WD TV live with an external drive of 2TB for the same price of a Hub (I have no difficulty in recognizing my past mistakes)?
Thank you for any help.
