Hey Guys need your help and advice
I want to buy USB wifi adapter for my WD TV Live Hub, cuz im really tired with this wired network.
So i saw that there is a list of some specific adapters which work.
I went to the shop and told them i wanna see if it works first and then to buy it;
So i brought my WDTVLIVE and tried two USB adapters they had that were on the list
TP-Link Wireless N USB adapter TL-WN821N Ver 2.2 (but they had v. 3.0)
and
D-Link Wireless 150 USB Adapter DWA-125 Version A1, FW 1.00 (have no idea which version they had)
So none of them turned on,i mean the light didn’t blink on the usb adapter either, and Network Settings couldn’t find anything;
So later when i came home i noticed that firmware should be
“The following devices have been tested and are known to be compatible with the WD TV Live (WDBAAx0000NBK) HD Media Player (using firmware 1.06.15_V) and the WD TV Live Plus HD Media Player (using firmware 1.06.16_B).”
But on this site i saw different
it says
The following devices have been tested and are known to be compatible with the _ WD TV Live Hub Media Center _ (using firmware 3.01.19) and WD TV Live Streaming Media Player (firmware 1.06.04).
Then i checked my firmware and as i saw it was 2.xx something;
So, what can i do? What is the reason for that?
Maybe i should buy the Lan-Wifi that plugs in not into the USB but Lan port of the Media Player? But will that work?
Plz advice;
P.S.
When i plug it in even if its working, should i install some drivers?
