I am using firmware 3.12.13 on my Live Hub.
In the last week it has suddenly started disconnecting from my network. I have multiple devices which stay connected, but the WDTV will suddenly disconnect, during use of Netflix, streaming tv through Playon and various other services.
It suddenly stops. If i go to network connections in settings, it shows that it is not connected. If do connection setup, automatic, it sometimes fails the first time, but always connects after a second attempt. The connection will remain for a random time, from 5 minutes to 20 minutes, and then disconnect, even when the unit is not streaming anything. (I know this because I left it idle overnight and it was disconnected the next morning). It does not correct automatically when powered off and on.
I have used the monitor on my router to see that the other devices (Iphone, laptop etc) all stay connected. Could this be a failing network component? It has always been completely reliable until the last week or so, and I have made no changes to the network setup at either the router or WDTV end. I dont know when the firmware update actually installed so I cant say that it was or wasnt related to that.
Rob
