Audio output problem on 1.06.15_v firmware
yesterday I update the wd tv live Media Player via internet with the 1.06.15_v firmware, but now I have some problems with the audio:
  • if the device is configured to use the stereo, output there aren’t problems
  • if the device is configured to use the HDMI digital output, the videoclip with mp3 audio are reproduced without audio
  • if the device is configured to use the S/PDIF output there aren’t problems
Why with the new firmware it is impossible to redirect the digital audio to the HDMI and the S/PDIF ports?
It is very disagreeable have to change the configuration every time you want to use the audio amplifier!!!
Try doing a roll back.   http://wdc.custhelp.com/app/answers/detail/a_id/5800/session/L3RpbWUvMTMyODEyMDQzNS9zaWQvSlpPdDNEUGs%3D
Roll back to the previous firmware, and use “digital passthrough” (not optical).  That will get you HDMI + optical outputs at the same time.
