I have just bought a WD TV Live which works fine in its condition right out of the box. So before I jump to upgrade I need following question answered. If there is a problem:
no way to that is easy⊠iâm stuck with my 2nd (after RMAâing the first-you think i wouldve learned a lesson and NOT upgrade the second one) useless wd tv box due to âupgradingâ the firmware. worked equisitely out of the box though i must say. iâd love a resolution but iâve given up and thrown it in a box somewhere.
The technical bit is that you have to update one of the included files to fool the WDTV into believing that it is a newer firmware otherwise it will not receive the downgrade.
Google âWDTV Live downgrade firmwareâ for more details.
Sorry, but I followed (nearly) every link resulting from your URL but I can find the HowTo but nowhere the Firmware itself!
Why does WD not make all versions downloadable? Nearly every other company does that.
I am not going to upgrade if I cannot reliable downgrade. Too many bad experiences. It is a reason for me to return the device back to the retailer.
*> Presumably they donât make them available because the old versions are obsolete and outdated (and might even be in violation of contracts made with youtube so they would open them selves up to lawsuits if they did make them available)>
I recently downgraded the firmware of my WD TV Live Media player. The firmware 1.01.24 doesnât work with iso-files verry well so I decided to downgrade the firmware to 1.01.17.
1.Use USB FLASH KEY from 64mb upto 2GB. I recommend upto 2GB but you could also use bigger ones but they using different adressing model
this could be issue for some models.
2.Format the USB FLASH key to FAT16 or FAT32 filesystem donât be lazzy and DONâT use NFTS for this case 1)
use USB FORMATER 2)or any others formatting tools.
3.Go to WDTV menu SystemâAbout there is version notice it you will need this number later.
4.Unpack firmware package to USB FLASH KEY to root directory there have to be 2 files WDTV.BIN and WDTV.VER.
5.Open with notepad or any textplain3) editor and change version in WDTV.VER to higher then you have in WDTV now if you dont change this new firmware will not detected as new one.Save the file.
6.De-attach all USB devices from WDTV unplug power supply wait 5-10sec plug-in USB prepared USB FLASH KEY and plug-in power supply.
7.Wait and dont reboot WDTV durring flashing process
Your link does not work as it stands and is not directly clickable.
I think this is the direct address for the official download
In fact there are 4 files included in the upgrade and the .bin, .fff and .ver files all need to be copied to the root of a USB flash drive which contains only these files and nothing else. Remove any drives etc from the other USB port
