03-16-2012 12:38 AM - edited 03-16-2012 12:40 AM
Hi All
Hi , after firmware upgrade to 2.3.01 i've messed up 2 My Wd
Now from 10Mb/sec file copy has gone to the incredible speed of 700kb!
I read in other posts that a possible trick is to downgrade firmware to wda4nc40000-02.01.92.img
An that there is a trick
"You can access the Device via SSh, there you can change the /etc the file Version, just modify 2.2.90 to 2.0.90. (Using VI) after that you can Update the Firmware to the version 2.1.92."
But the following link does not work
http://download.wdc.com/nas/wda4nc40000-02.01.92.i
Anybody has a working link where I can download it.?
Thanks in advance
Luca.
03-17-2012 08:36 AM
Did you tried to reset the Sharespace?
03-19-2012 02:16 AM - edited 03-19-2012 02:16 AM
If you mean Factory Default Restore
Yes
The firmware remain the last so the network speed is 700 Kbps...
As I said I read in other posts that the only chance to return to 10/mb sec (not more also it is declared as gigabit)
Is to come back to 2.1.92
If you have can you give me?
I see that there are ways to compile non official firmwares or the same official gpl's
I does not found the 2.1.92 and I've never compiled a firmware.
I don't want to miss something and put my wd to trash
If anybody have some working firmware, plz post a link where it can be download!
| Forums | Ideas | News and Announcements | Register | Sign in | Help | Forum Guidelines | |
