Does anyone know where I can find info on how to perform a complete system restore of this unit?
Mike…
Mike…
Thank you very much…
In recovery mode a format is performed.
I have the 8 TB version. How long will the format take?
Or how long will the whole restore process take?
Thanks …
Took me over a week, but it was because I had issuses and had no clue what I was doing
You know start the download, machine patches and reboots overnight while the DL is in progress.
I should have taken better notes, But it should not take over a couple of days before you can start using it
Well it has been formatting for about 10 hours now & maybe the progress bar is at 10%.
At this rate another 3 to 3 1/2 days just to format.
I had an 8 gb box but only restored to 2 drives, so I just don’t remember how long. As long as it is progressing that is good.
I wanted to get the add drive expirence
