The 3 TB drives are brand new and function fine, but the Sentinels hang at “Loading OS” if you try to boot them with the drives attached. Searching Google for “MyBook 3 TB boot” will show that this is a widespread problem.
It isn't marked as bootable / active:DISKPART> list volume
Volume ### Ltr Label Fs Type Size Status Info
Volume 0 C NTFS Partition 60 GB Healthy Boot
Volume 1 D NTFS Partition 1802 GB Healthy Pagefile
Volume 2 FAT32 Partition 100 MB Healthy System
Volume 3 A 3 TB WD NTFS Partition 2794 GB Healthy
DISKPART> select volume 3
Volume 3 is the selected volume.
DISKPART> inactive
The current partition is already marked inactive.
DISKPART> attributes
Microsoft DiskPart version 6.1.7601
VOLUME - Manipulate volume attributes.
DISK - Manipulate disk attributes.
DISKPART> attributes disk
Current Read-only State : No
Read-only : No
Boot Disk : No
Pagefile Disk : No
Hibernation File Disk : No
Crashdump Disk : No
Clustered Disk : No
DISKPART> attributes volume
Read-only : No
Hidden : No
No Default Drive Letter: No
Shadow Copy : No
DISKPART>
I want to update to say that I did receive a reply via email (that was blocked at our border because of the use of the salesforce.com domain). The problem is that there is no update posted to the ticket itself on the support portal, which is what I was monitoring.
Beyond that, the initial response was “the unit is not intended to boot up when there is any USB device attached to the USB ports”. We’ve had 3 units work flawlessly with many different models of external drives over the years. ONLY the 3 TB MyBook USB 3.0 drives cause this issue, and anyone Googling “MyBook 3 TB boot” will see it’s not an isolated incident nor is it restricted to the Sentinels. Further, reviewing the firmware update release notes for this drive reveal that it has had (and continues to have) issues with power states.
Another rep from WD has reached out to me. If I get any solution or workaround I’ll post it here.
