I have had to do an RMA on this unit due to the fan failure, and unfortunately I will have to send the entire system back…
but of course, there is a lot of data to move and it would be a lot faster if I could remove the drives and put them into say, and external array, or even throw a system together with a compatible controller to do the transfer to another block of storage.
Are there any compatible raid controllers that you can recommend for this and/or what exactly “is” the raid controller in this thing (chipset would be helpful).
thanks!
