Win 8 My Computer does not recognize My Passport Essential - power light is on
Shows up in device manager and disk management and is connected but cannot read/access the external drive. “No writeable WD Smartware partition found.” USB drive works with other devices. could usb cable be bad? if so, how do i replace?
thank you.
It is possible that the USB cable is not working properly. I recommend you contact support directly for assistance with this.
Contact WD
I followed your instructions for repartitioning the drive and it’s working fine now. Great directions!
