How to connect a wd 1tb external drive to a toshiba thrive tablet
how to connect a wd 1tb external drive to a toshiba thrive tablet, its not connecting, how do i get it to connect
anyone has a soultion???
Not sure if this one will work
portable drives need to get sufficient power to work, not sure if the tablet will provide enough juice
check the specs for the tablet to verify what kind of drives can be used and what file system
