Hi
My disk with above mentioned specifications is undetectable across various windows OS.
It does not appear in d disk management section too.
It ontains a lot of important data. Kindly assist.
Thanks in advance.
Hi
Thanks in advance.
Try diff cable. Also check universal serial bus controller under device manager. If you can see a yellow triangle you need to update ses driver.
