Reply
Occasional Visitor
Bg1bpe
0
Problem with my Passport USB 3.0
I have install my Passport during Windows 7 , and that work FINE..
But when I try to use it , on my another PC( during XP),, i got : Error..
MY Q = Can't I USED ON BOOTH - XP AND WINDOWS ( SWITCH WITH NEED)..???????
bEST REGARDS- Bg1bpe - from Swe
Honored Contributor
ThePizzaMatrix
0
Re: Problem with my Passport USB 3.0
Hi dude!!
What specific error is the one you get? It can be extremely helpful since there are tons of possibilities in here!
You should be able to use that drive on the 2 OSs, but a lot of things come into play like stability, the age of the computer, updates, drivers, optimization and overall configuration just to mention some!
Hope it helps!
You are reading a ghost long gone.
Esteemed Contributor
Lawrence
0
most likly you are useing the 3.0 cable try using the micro 2.0 cable for xp.
"Study the lie and they will make new lies up...Study the truth and you will know when the lie comes."
