Reply
Occasional Visitor
jsquareg
0
Portable Disk - WD My Passport Problem
I recently bought a WD My Passport (500g) USB 3.0 portable disk and am having 2 curious problems with it.
Under Windows 7 Home Premium the I have the following 2 problems.
1. When I plug it into a USB 2 port, I get a message saying that it could perform faster if it were plugged into a USB 2 port. I wouldn't be surprised if it said a USB 3.0 report.
Most Important though is the following:
2. If I open the disk to view the contents and close it several times then try to 'safely remove' it I get a small window whose title says Problem Ejecting USB Main Storage Device with the reason given is The device is currently in use. Close any programs, etc.. If I immediately, without closing that window, try to safely remove it using the little USB icon it the Safe to Remove message appears.
I do not have a USB 3.0 card installed yet.  I want to get the disk working smoothly on USB 2.0 before taking that steip
Other than that, the disk seems to work just fine. Anyone have any thoughts how to correct this situation?
Thank you.
Honored Contributor
Wizer
0
Re: Portable Disk - WD My Passport Problem
Try this solution
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Occasional Visitor
jsquareg
0
Wizer wrote:
Try this solution
I clicked on solution but only found a list of support sites or something like that.
Honored Contributor
Wizer
0
My Bad try this one
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
