Reply
Occasional Visitor
karlochacon
0
Plan for 1.5TB Portable Drive?
hi guys
I am having troubles keeping some space in my WD Elements 1TB, I was searching and found some other manufactures have 1.5TB not that realiable I've read so since I've have 2 WD Disk without any problem I would like to know if you have a release date or if you are planning to release 1.5TB Drives usb powered?
thanks a lot
Occasional Visitor
karlochacon
0
Re: Plan for 1.5TB Portable Drive?
don't worry guys
I found what I was lookinfg for...it's even a bigger drive 2TB
http://store.westerndigital.com/store/wdus/en_US/DisplayProductDetailsPage/categoryID.58729200/subCa...
thanks
Honored Contributor
Wizer
0
[ Edited ]
yup
fresh on the market :smileyhappy:
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
