No Writable SmartWare Partition Found | Pls Need HELP
Dear Sir Or Madam
Have a nice day
I will explain my Problem in following points:-
Introduction:
  • am using "WD My Passport Essential 500 GB " Since SEP-2010.
  • i have password in “VCD”
  • When i entering the password then “MyPassport Hard Drive” Will appear.
  • i used my “WD Passport Essential” in my Laptop at Home & in my PC at Office.
    Problem:
  • Before 2 Days i have connected “WD Passport Essential” in PC at office.
  • i Unlocked, then When i Browsing my files the Device was Hang-up (FREEZE).
  • i removed the USB cable from PC then i connected again.
  • again i Unlocked, the am to able to open "WD My Passport: Drive…
  • Drive is appear in my Computer, But the size is 0 (Zirro).
  • When am trying to open the drive… Error message “No Writable SmartWare Partition Found”
  • Also This message " The Disk in Drive “P” is Not Formated… Do You Want To Format Now ?"
  • i have Very Important DATA saved in " WD Passport Essential " Drive. i don’t want to loss it.
  • i want your Kind Support… How can i solve this Problem Without Losing my DATA ?1
    Pleas Help My
    Thanks & With My Best Regards
    M. H. Kambal
Sounds like a data corruption program, once you unlock the passport you can use a data recovery program like recuva or test disk to scan the passport. Check the links below.
http://www.piriform.com/recuva
http://www.cgsecurity.org/wiki/TestDisk
Do the following thinks:
  1. change the USB cable
  2. test to other computer.
  3. If it has power cable, examine with the same voltage of other Power Cable
