Hi WD community, i have a problem with my WD smartware code (WDBAAD0010HBK) i did a copy from my computer to the external drive so i can install windows 7 on my pc… everything cool and perfect 'till now… i could enter and see my documents… (note: i didn’t copied with the wd smartware program, i just did copy/paste on external drive, the one with 990 GB) and i checked to be sure that i have copied all of the data and cheked if works to copy back and use that data…) ok so i installed my windows 7 and i just wanted to copy all my folders from external drive to computer… installed the wd driver/program etc. but the external drive did not appeared… (H:990GB) my computer knows that i have connected the wd to pc and shows me that it is connect but tells me that has 0% usage and can’t restore any of the data… all my work for about 5 months day 'n night are in the drive… anyway i took a program called Wondershare data recovery and found all of my data on disk but cannot recover them because could not find the drive H: what can i do?!?
p.s sorry for my english…
