Jayce
February 27, 2013, 6:20pm
1
Can anyone help me how to fix this problem?
No files are hidden.
When I click the K: drive nothing appears except the unknown file
Can anyone help me regarding this problem?
http://i629.photobucket.com/albums/uu17/chelzynd/Picture1-5_zps1e786c7f.png
Jayce
February 27, 2013, 8:52pm
3
Yes I’ve connected it to another computer. I’ve encounter the same issue. I have tried may USB cables. Nothing happens.
What would be the file type or extension?
Also try to scan the drive for viruses.
Jayce
March 1, 2013, 3:55pm
5
Try to do this first. http://wdc.custhelp.com/app/answers/detail/a_id/940/session/L3RpbWUvMTM2MjAwNjU4NS9zaWQvWWlpZmpYamw%3D
Do you have important files inside the drive? If not try reformatting the drive using the write zero type of formatting using the application on the link.
Jayce
March 1, 2013, 4:16pm
7
Yes. In fact all files are important I’ve tried the quick test but it failed. Right now I’m doing the extended test
Jayce
March 1, 2013, 5:09pm
9
thanks for the link. but the countries listed are too far from my country.
