Help: Doesn't recognize when connecting on TV
Hello, can anyone help me??
I just bought my Passport 1T  to migrate from my old PC to my new Mac, and it works fine. I had to format to Mac, so it doesn’t work on windows anymore but no problem.
The only thing is, when I try to connect it to my TV to watch my movies, it doesn’t recognize it. The light are on and everything, but the TV doesn’t run it. Was it because I formatted it to work on my Mac??
How do I solve this? Should I download something else
Well some TVs only recognize external HDDs formatted in FAT32, if you formatted your passport for Mac is provable that you used the HFS+ file system, so chk the manual of your TV to see the supported formats.
you can format your hardisk in exfat format
