I just purchased a new HP Envy H8 which has two USB 3.0 ports on it. Machine is Windows 8. I was thrilled to have this to use with my WD Elements SE 1TB USB 3.0 drive, however, I am not having much luck.
When I try to copy large amounts of data (i.e. all of my music or pictures), the transfer starts, but after a few seconds, I either get a message that the data can not be found on the drive, or sometimes it just acts like it’s finished, but clearly is not after only 3-4 seconds. When I look, only a small amount of the files were actually copied over (i.e. maybe 5 music folders out of 300).
When I plug the drive into a USB 2.0 port, it is obviously slower, but at least the data actually copies thoroughly.
I looked online and didn’t see any sort of drivers that I could install that might address this, especially given Win 8.
In case it matters, my hard drive is a 2TB 7200 rpm SATA (drive that came in the Envy H8 1445). Not sure of any specs beyond that.
Any thoughts?
