Reply
Occasional Visitor
0
Accepted Solution
Dual USB cable for Passport Essential
I'm looking for a Dual USB cable for Passport Essential (USB3) as my laptop seems to be weak in power.
Where can I find in US?
Thanks,
RON C
Honored Contributor
0
Re: Dual USB cable for Passport Essential
Try Google.com
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Occasional Visitor
0
Spent a very long time on Google with no success.
Tried again and found this on Brit site:
AA2USBPC  Dual USB power input adapter cable. Combines the power of 2 USB ports into one.  Addonics part reference: AA2USBPC
Saw reference to Addonics and found there.
Thanks,
RON C
