Even when the drive goes to sleep, the power adapter is still consuming energy. The only sure way to know is to measure it. If you are electrically inclined, you can use a mutlimeter in ’ current’ setting to get the usage, or invest in a device like a KillaWatt, which can monitor and provide all the info you are looking for.
