Anytime Backup Premium - Stability Problem
I have the Anytime Premium trial version of software installed on a 32 bit Vista machine.  I created a backup plan to backup the C drive to a network drive.  It sort of worked.  It would run for a bit then generate an error message about WD Anywhere Client stopped working, then it would shut down.  I set up a second backup plan to backup the D drive to a different network location.  It sort of worked for awhile.  It showed both backup plans working but now you cannot even start the software without it generating the WD Anywhere Client stopped working message.
Can anyone help or recommend a more stable product for network backups?
Keith600
