Reply
Occasional Visitor
crossrunnerzero
0
WD SiliconDrive II Problem
I am using a data logger that uses the WD SiliconDrive II. I swapped it out for a WD SiliconDrive I with a higher memory capacity. However, the data logger can not seem to read the memory card anyways. I heard that the new memory card needs to be reformatted for use, but I tried that and it didn't work. Maybe I tried reformatting it wrong or something. Anyone else with this kind of issue?
Honored Contributor
Alucardx23
0
Re: WD SiliconDrive II Problem
Did you check the compatible formats for the data logger?
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
