Reply
Occasional Collector
andy1234562
0
WD Elements Desktop 1TB (WDBAAU0010HBK-AESN) - Adapter Problem
Recently my WD Elements Desktop 1TB stopped working when I plugged the adapter in...There was no flashing light. So I figured that the adapter probably stopped working. :manmad:
Anyways, where do you get another adapter? And to add...my adapter needs to be in DC.
Also, has anybody else faced the same problem? And how did they solve it?
Esteemed Contributor
Awopero
0
Re: WD Elements Desktop 1TB (WDBAAU0010HBK-AESN) - Adapter Problem
Contact WD they can provide with the correct power adapter for your drive.
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
