Reply
Occasional Visitor
Solomone
0
Please Help To Fix my WD EXternal Hard Drive.
Please I have an External WD HardDrive, someone use it and she can't read any data from it. and she gave it to a IT shop to fix it but they can't fix it. and they broke it. I have no idea where to fix it and who will fix it.because they have broke it into piece only the hard drive is still unharm.
Please can anyone help show me where is the nearest WD Technician Office, whom will help fix my external Because it is so helpful for me.
I am Solomone Moala, from Tonga.
Thanks..
Honored Contributor
Wizer
Re: Please Help To Fix my WD EXternal Hard Drive.
support for WD drives is provided by phone or email..
did you try contacting them already?
Click the Kudos star to say thank you for helpful posts and be sure to come back and 'Accept as Solution' under options for the post that solved your issue.
Copyright © 2001 - 2010 Western Digital Corporation, All rights reserved. | Trademarks | Privacy | Terms of Service | Terms of Use | Copyright | Contact WD
