Reply
Frequent Advisor
0
How much power do my 2 TB WD External Drives use?
Hi, I have five 2 TB Western Digital Elements External Drives and 2 My Book external drives. I have a Western Digital TV Live Media Player and I would like to plug 6 of my drives into the Media player at the same time but I was concerend that they would use a lot of power. How much power does one 2 TB Western Digital Elements Drive use? How much power would six 2 TB External Hard Drives plugged in to the power outlet at the same time use. Do they use alot of power?
Honored Contributor
0
Re: How much power do my 2 TB WD External Drives use?
I would not do that if I were you....
You are reading a ghost long gone.
Frequent Advisor
0
May I ask why?
Frequent Advisor
0
i work on hard drives and i had 10 hard drives hooked up to my pc at one time short story 4 of the hard drives work now so do the math
(TSK)
Frequent Advisor
0
I appreciate the help. Is it then best best to power them down when not in use?  These externals will be plugged into a USB Hub hooked up to a WD TV Live Media Player.
Frequent Advisor
yes if your not useing them then unplug them this will
1.save power
2.the drive will last longer
3.and keep the drive cool
this is a solution
(TSK)
