Anyone;
I am having difficultly connecting two Livewires together that are in separate buildings. Both buildings are fed from the same power source but the 2nd building is 200 ft. away from the main power feed and the power in the 2nd building passes through 2 breaker panels. The livewire boxes work just fine in the 1st building that have the main power feed. I have tested various outlets in the 1st building that has the power feed and the Livewires work great.
The 2nd building’s power passes through 2 100-AMP breaker boxes. The breaker boxes have 220Volt circuits with ground and then an additional earth ground is on each of the Breaker Panel as well. There are no ground fault circuits in the 2 100-AMP breaker panels.
Does anyone have any suggestions?
Thanks in advance for reading.
