I have Enabled Remote Management option and tried it with and without https turned on but I have been unable to remote into the router from the internet. Is there something I am missing?
Remote Admin Port Port that will be used for remote management connections. Default is 8080.
FYI - The Remote Admin Port cannot be used in an external port range of any port forwarding rules.
Did you try with that port number that you specified for the remote access? usually 8080
The syntax would be
https://:8080
for more details please see this manual
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705074.pdf
Page 57
Yes tried that one and the 8181 port that it defaults to when you turn on https.
Have you been able to get it to work? I just tried to update the firmware and can’t even get it to work
*edit*
Tried with newest firmware, still doesn’t work. Has anyone got it to work?
