Background:
Uverse TV/internet
3 wired devices (non Uverse) on 100Mb switch attached to Uverse gateway
multiple wireless devices
poor coverage on patio
Want:
wireless N connections
Better signal on deck
USB connected drive on network
parental controls
Time of Day filtering
Guest account
gigbit connections between computers
I have a new N900 in the box ready to install, but wanted some feedback first. If I set it as an acess point by
Turn off DHCP on your router.
Change the link between the 2Wire router and your router to use the LAN ports on both ends. (In other words, plug the cable from one of the LAN ports of the 2Wire to one of the LAN ports of your router. Leave your router’s WAN port empty).
Change the LAN IP address of your router to a static IP on the same subnet as the UVerse 2Wire router. For example, if the 2Wire router is using 192.168.1.x, and the DHCP range is 192.168.1.64 - 192.168.1.253, set your router to 192.168.1.10.
If necessary, configure the wireless parameters on your router, such as SSID, encryption, pre-shared key, and MAC filtering.
Will I be able to use the features listed above? I would rather be able to see my Uverse boxes on the same subnet so they can stream pictures from the PC, but can live without that if I have to. Then I would have to do a router behind router config which can get a lot more complicated quickly. The Uverse box must be there to connect the TVs, internet, and phone, so that can’t be removed. I can disable the wireless portion and run everything through the N900.
The instructions for router behind router are as follows…
Set your router’s WAN interface to get an IP address via DHCP. This is required at first so that the 2Wire recognizes your router.
Plug your router’s WAN interface to one of the 2Wire’s LAN interfaces.
Restart your router, let it get an IP address via DHCP.
Log into the 2Wire router’s interface. Go to Settings → Firewall → Applications, Pinholes, and DMZ
Select your router under section (1).
Click the DMZPlus button under section (2).
Click the Save button.
Restart your router, when it gets an address via DHCP again, it will be the public outside IP address. At this point, you can leave your router in DHCP mode (make sure the firewall on your router allows the DHCP renewal packets, which will occur every 10 minutes), or you can change your router’s IP address assignment on the WAN interface to static, and use the same settings it received via DHCP.
On the 2Wire router, go to Settings → Firewall → Advanced Configuration
Uncheck the following: Stealth Mode, Block Ping, Strict UDP Session Control.
Check everything under Outbound Protocol Control except NetBIOS.
Uncheck NetBIOS under Inbound Protocol Control.
Uncheck all the Attack Detection checkboxes (7 of them).
Click Save.
Has anyone done the Uverse thing with this router? What configuration do you you recommend to still use the USB and guest accounts?
Thanks,
Dennis_H
